Anyone offer a new tranny gear for a 5spd fit?
#41
Okay, it looks like a site like this would be helpful to answer some of these questions. Hope this link copies okay, but here we go. Assuming we have accurate gear ratio data:
MFactory Competition Products - THE Replacement for Displacement!
#42
Changing to a longer final drive (lower ratio number) won't just affect your 5th gear, but all 1st-5th gears. Unless you have the power available, this is going to bog your car rather seriously, especially on a FIT.
For the fuel economy aspect, changing to a shorter final drive (higher ratio number) might actually increase your mpg due to less load/throttle during normal cruising speeds. This has been shown to be the case on both D-Series and B-Series, although we've still to test on the FIT.
#44
If I'm not mistaken, it looks like the new 2009 MT version actually has a higher actual gear ratio (5th gear ratio x final drive ratio) than the 2008 manual:
2008 2009
3.24753 3.35874
So the 2009 would rev even higher at highway speeds? Is that right?
Frank
2008 2009
3.24753 3.35874
Frank
