Scangauge velcro failing in heat
It was about 95 degrees here yesterday and when I came out to my car, my scangauge was nowhere to be seen. It took me a moment but I realized the glue from the velcro had melted and the scangauge had fallen off. Anyone have any methods of getting around that problem?
i haven't had that problem. and we've had weather hotter than that. where are you trying to mount the scangauge? i have mine on the top of the steering column cover and it doesn't seem like it'd go anywhere
Gluing to vertical plastics is not a good project.
good luck
you'll need to find the velcro with the red backing. the velcro w/ the blue backing isn't designed for high-heat apps. i found that using when i used regular blue-backed velcro to mount my tollroad transponder.
they sent some more velcro and it had the red backing on it.
-e
btw-i couldn't find any black colored red-backed velcro, though....only white.
-e
I picked up some 2" wide stuff at Home Depot after the first time it came off and that stuff hasn't let go. I have my unit hanging from the velcro so gravity is a factor in my install also. The original fuzzy stuff is still on the unit.
startroops
09-12-2007 01:44 PM
zZero
05-04-2005 11:16 AM
