Anyone try "half tank fillups" technique?
Problem with keeping the tank 1/2 empty . . .
It's actually better to keep your tank full, than to run it empty-to-full ALL the time. Other than the advantage of a minor weight reduction/minor improvement in mileage, you will increase the chance of water in your fuel. Water vapor in the air, especially in humid climates, will have a tendency to condense out in the tank. As you constantly pull fresh air into the tank as you burn fuel, you will also bring in more moisture/potential condensate.
Drive On!
jT
Drive On!
jT
Guest
Posts: n/a
I usually fill halfway or 3/4th's every time. been doing this for over a year. i cringe everytime i do it, as we all recall that the more air space in the tank leaves more room for gas evaporation (i.e.: waste). but if your numbers do support a better MPG due to less wieght, i will not argue.
Drive On!
jT
Drive On!
jT
That's why fuel treatment was invented. I bought a bunch of cheap ones for about $1.50 each bottle. I'm at half tank right now and I put 7 gallons worth of treatment. Car feels lighter and engine feels a little smoother. I'm going to try other concentrated fuel treatments in the future within 1,000 mile intervals. Whohoo... $1.50 per 1,000 mile, $.0015 per mile. Also, I'm treating with 5 gallon intervals, so I can spread one whole bottle 2 times. So it's $.00075 per mile now.
SOMEBODY STOP ME! I'M TROWING AWAY TOO MUCH MONEY!
coldstorage5
08-07-2006 06:50 PM
