Did a DIY intake on my 1 day old Fit :)
About $50 in parts... and only took about 30 minutes to swap. I will add another 90 degree bend and aim the filter to the driver side, but they didn't have one readily available today.
Index of car stuff\2008-Fit\2008-03-28 Intake\ - ASP ListPics
Yep needs the second elbow. That part of the under hood area had one of the highest underhood temperatures recorded in the testing I did. Moved over the 3-4 inches toward the fender opening with another 90 is a lot cooler. It they have extension pieces try to get the filter as close to the original opening in the fender as you can as the air gets cooler the closer you can get to the opening in the fender.
Nice work looks almost like it came that way. The color is a great match for the car. With the extra elbow the front end of the filter is in one of the coolest temperature places under the hood. Should work great. With you living in Texas and not having very cold temperatures to deal with any though on bypassing the hot water going into the TB?
yovtecjustkickedin
13
04-05-2015 02:08 AM
Pepperinyoureye
203
11-04-2008 11:08 PM
Skierdood
09-23-2008 09:19 PM
F'it_ImFromTx
13
04-20-2008 06:59 PM
