Gas Milage
Theres so many variable's when it comes to MPG's. Where you drove how hard you drove, wind, hills, tire pressure, speed. Check your tire pressure theres a good chance that its low. Check them when they are cold(morning) and make sure they are 32psi.
Tyler
Tyler
I haven't been following the weather across the country, but how's the weather in vegas? Did the temp drop fairly drastically lately? Cooler weather creates more power through the dense air, which in turn lowers your mpg's, where as warm air will do the opposite
If you use the defrost mode, your fit will use the AC. Unless you disable it by the modification described here https://www.fitfreak.net/forums/fit-...solutions.html
just out of curiosity, but do any of you watch mythbusters? they ran tests to see if running the a/c would reduce gas mileage and it does not have an affect on mileage at all, the whole idea of running the a/c with the defrost is irrelevent to this situation anyhow
A/C will reduce gas millage on a small engine like the Fit's. It uses some of the engines power to make the system work so the engine has to work harder to achieve the same performance and therefore MPG's go down.
so if you would truely like to save on gas mileage you're going to have to pull you're entire a/c compressor out of the engine bay, or just disconnect the belt
I agree but we can both agree that having the A/C on will reduce gas mileage or at least it has for me in any car I've ever driven. It also makes a car with a small engine feel more sluggish when it is engaged.
I wouldn't know how it feels kicked on in a smaller car. I've always driven accords until now, but it shouldn't hurt the fuel economy. I still think that it shouldn't hurt the economy
When the Air Conditioning Compressor is running it reduces your mileage by a LOT!
Anyways after doing the NO AC defrost modI'm back on track to good MPG, I just pulled 434KM out of 34 liters of gas. And that's with me redlining it ferquently
It most definately does in the Fit. And yes, the AC pulley is always there, but when the compressor clutch is disengaged there is NO resistance on it, and no drag on the engine.
