Shifting a Sport 5AT?
At 60 the MT does ~2900, if I remember right the AT @60 is ~2300. If you do mostly long highway trips, your gas mileage may slightly better on the AT vs MT because of this difference (but not nearly as much as you'd think), but the MT gets a lot better in the city.
Mileage
The paddle shifters, while fun, normally drop my MPG from 29-30(in D) to roughly 25 or 26. While I enjoy having the convenience of an auto (much easier to eat and drive), I would definitely rather have the 5spd if I had a choice. However, I would have had to wait about 1.5 months before the next M/T would come into the dealership so I decided not to wait.
The Fit's S-mode definitely lets you sit at redline if you don't self-shift up. However, it will downshift for you as you are slowing down, which is nice in case you forgot that you're in S-mode.
There seems to be much confusion about how the paddle shifters work. This is how they work in MY Fit:
In D, I can paddle shift up or down. The car will then override my shifting when it wants to (I've not fully tested the conditions).
In S, if I don't touch the shifters, the car will shift from first to second to third. During my commute, I was unable to go fast enough to see if it will shift into fourth. These shifts occurred at about 3000 rpm, while in D, they occurred at about 2500 rpm.
Once I use either paddle in S mode, I am now in manual mode, and the engine will redline if I don't upshift. I haven't fully tested this, as I do not like the sound of the engine near redline, especially if I'm only going 20 mph. However, the car WILL downshift by itself, usually skipping second, and going right from third to first as I stop. I can shift into fifth gear from fourth only if I am going above about 35mph.
Is this behavior different than anyone else's car?
OK I think I'm sold on the 5 AT.... now I like some feedback from 5AT users than came from a 5MT (any car)... so how have your driving habits changed? do you use the M mode or S mode or just leave it in Auto.
Do you usually shift on fwy on ramps? when do you actually paddle shift?
Thanks... I know lots of questions, sorry
Man I'm hooked on the 5AT... thanks. Earlier I asked about the 'security system' can anyone chime in?
The brochure says Immobilizer Theft-Deterrent System (standard) and Security System with Remote Entry (sport only)
So does the Fit have an audible alarm (horn) or motion sensor (I guess that's too much to ask) but if someone breaks in thru the door or hatch will the horn sound?
It does have some form of a alarm, idk how she set it off, but my mom set it off while i was washing the car.
I dont know if it has a motion/shake sensor, but it probably will set the alarm off if you open any of the doors while its set. Real eazy to test, just roll the windows down, set the alarm then open a door, pop the hood or the hatch, and see if the alarm goes off. I imagian it does since somebody said you cant hit the lock button twice and honk the horn if the hood or hatch is poped.
Once I managed to set the alarm off, but I forget what I did. I don't think its a motion or touch sensor (touching the car doesn't seem to set it off).
there is no motion sensor.... press the button by the door opening and foul the car that the door is closed, engage the alarm.... nothing happens no matter what u do unless u release that button and the car thinks the door is open
#36
I have definitely gone into 5th in S mode.
You might want to double check your car.
#37
Same here, but i burn gas like a MOFO.... =|
it's amazing how it feels spending 3.89 a gas on regular unleaded after only 160 miles of driving (i reset my trip meters on every fill up) it looks and sounds cool to drive like that, but it does have its costs if you rev up a lot.
But man, i could get higher speeds on S than on D. =D
#39
in S mode the car will only go to 5th after 35 or 40mph any less it will only go up to 4th
#40
I can't remember exactly here, but this is my recollection after driving both quite a bit and trying decide whether this was one car with an AT I could buy (I have M/T but really tried all the AT options when testing to see if I wanted one....)
There are basically 2 'S' modes, the 'sporty automatic mode' for those who want to have more kick but not do any shifting, and a 'sporty manual mode' for those who want to shift.
The first time you touch the paddles in 'S' mode you go from 'sport auto' to 'sport manual'.
If you drive in S mode but don't touch the paddles, it will auto shift for you, but
a) the shift rpm points are somewhat higher than in D mode and;
b) I don't think it will go into 5th by itself (redline in 4th on an AT is pretty fast and is probably past top speed....) - You'll have to 'paddle it' into 5th gear if that's what you want.
Once you touch the paddles in S mode, the rules change:
a) It will only auto shift up to 3rd gear if you don't, but not go past it. You'll have to shift up if you want to go up from 3rd gear (~60 mph redline?)
Either way, it will auto shift down for you if you are stopping.
It's covered in the manual - hope I got the detail right - it's a bit confusing because they seemed to want to cover all the bases.....
