strange gas cap question
i was filling the fit today and noticed it dosent have the standard plate the blocks the hole where u put the nozzle in. does your car have one of these if so im bummed cause that means mine is somewhere in my gas tank.....HELP!!!!!
COOP
COOP
My European Jazz also have this little metal flap. But the hatch in front of the gas cap is locked when I lock the doors on my car. I understand that it is not a lock on this hatch in the USDM Fit?
That little flap is probably just a safety measurement to prevent some items to drop into the tank. I cant think of anything else. It is just held up with a little spring and you can push it easy with a finger. It may be also be a safety thing to prevent gas coming out of the tank when the gas cap is off? Cant see any rubber seals on it so it is not very good sealed when closed...
In the US the "flap" was originally designed to prevent using leaded gas in a catalyzed car (the leaded nozzles were bigger but could be still fill the tank without a flap). Since leaded gas is no longer available in the US the flap is no longer needed. My Xterra doesn't have a flap either.
Epoch
09-06-2009 09:09 PM
