Cold Clutch? Shutter?
Anyone else seem to notice a shuttering of the clutch when you roll out to work in the early morning? When the car is warmed up, it seems to go away, but I've been a bit worried about it since it started happening a week after I purchased the car.
I don't drive hard at all, can anyone else relate? Do you think the dealer will fix anything? Oh and this should be obvious, but the transmission is a manual. thanks...
Posts in the NUUDE
Mine does it also... I think mine does it because I didnt break in the clutch properly. Its only when its cold though. After I do a few normal take offs it goes away.
What was the mileage on your car when you bought it? If it was test drove before you (other than PDIing) then it was probably beat on without a proper clutch break in.
I think it'll be fine. Unless its REALLY bad.
Mine's done it pretty much since I bought it, and like others have mentioned it goes away completely once the car warms up. It doesn't slip or cause grief otherwise, so I'm just gonna leave it alone since it's seems others have it as well.
Personally I wouldn't ignore it because although the car might be working it's still shaking the transmission and some other component might be suffering from that.
scottbikesalot
07-06-2018 05:26 PM
YeeFit
05-09-2009 09:34 PM
