fan noise?
Old 12-31-2006 | 02:28 PM
stacey14's Avatar
fan noise?
so i swear i saw this posted like four months ago, long before i had any trouble with fan noise, but the search engine can't find anything, so i'm posting again. nearly every time i turn my fit on, the fan starts raging. it can be hot or cold outside, moving or not moving, and it's still blowing like crazy. i thought it might go away, but i just hit seven months and it's still going. has anyone else had this problem? i know it's normal for the fan to be on sometimes, but it just seems to be a little much. any info would be appreciated.
Old 12-31-2006 | 03:13 PM
quangalang's Avatar
your AC is on, do you have it on defrost
Old 12-31-2006 | 05:52 PM
stacey14's Avatar
no, nothing's on.
Old 01-23-2020 | 09:02 PM
Karen Jean Prochacki's Avatar
Fan Noise
I’m not sure if this is the same issue that you are talking about, but a while ago my Fit developed only two speeds: off, or full blast when it was on. I took it to the shop, and it was a faulty fan blower resistor, which allows you to set the air at lesser speeds. Now, my blower is acting up again...sounds like a propeller going when it is on...makes a bit more noise when I drive it. Anybody know what it could be?
Old 01-26-2020 | 08:31 AM
knope's Avatar
My cabin fan squeaks from time to time, but switching modes from low to high usually clears the issue. I don't notice it enough to justify ripping up the dash to find and lubricate the fan bearing.
However from the wording of the OP the tags lead me to believe cabin fan- but then there's engine related tags as well. Is this the cabin fan, or radiator fan you're posting about? Are you just the kind of person that uses all the hashtags because "hipandtrendy"? : P
Old 01-26-2020 | 09:04 AM
Cabin Fan Noise
It’s the cabin fan I’m talking about. With my issue, the sound increases if I turn the fan speed higher. It also seems to become more pronounced if I have been driving at high speeds for a while. I am guessing it is either the fan itself or the blower motor. If anyone else here has any insight on this, I’d appreciate it. I’m sure replacing a blower motor is a pretty costly repair.
Old 01-26-2020 | 11:38 AM
knope's Avatar
Can you reproduce and record the noise? With mine it's sporadically audible as a squeaking noise.
der Mond
09-21-2017 12:48 AM
hogwylde
09-29-2011 03:44 PM
Fit of RAGE
08-02-2009 10:42 AM
Mugen_Dom
05-13-2006 11:18 PM
