Accidentally used a few Tbsp of silicate coolant
Hey Fit Freaks!
Question for ya: I recently put a little bit of green coolant directly into the radiator without first reading that I should have used blue silicate-free coolant. It filled up to the top very quickly, meaning I didn’t actually use that much coolant — probably 3-5 tablespoons at most, maybe less.
Then I looked at the user manual and saw I should be using silicate-free coolant.
I’m considering doing a coolant flush to clean everything out. I called the Honda dealership and they recommended it — but of course, they’re financially incentivized to recommend it. It’s pretty pricey, and I’m wondering if it’s really worth it — especially since I ended up buying silicate-free coolant afterward and putting it into the reservoir, which hopefully should dilute the coolant overall.
Is it worth it to spend $1-200 on a coolant flush because of a few tablespoons of silicate coolant? Or am I safe skipping that?
Thanks!
Jesse
Thanks!
Jesse
milesperhoward
06-10-2021 08:34 AM
theo.chan@gmail.com
10-19-2005 02:39 PM
