Sponsored by:
Sponsored by: CARiD
cheaper or universal o2?
Old 05-24-2009 | 03:40 PM
im the fit's Avatar
would anyone know if there would be a universal o2 sensor or a cheaper one/
Old 05-24-2009 | 10:00 PM
HONDAMATIC's Avatar
not worth it, sometimes you gotta cut and paste with your harness etc..
Old 05-24-2009 | 11:08 PM
im the fit's Avatar
that would be the last of my worries , I soldered my F/ic. I would like to just find a cheaper o2, I dont mind cutting or soldering. A bad o2 messes up your AFR's really bad = ( according to my gauge
Old 05-25-2009 | 12:24 AM
Mr08FiT's Avatar
You know it's a bad o2... Do you have a cat delete? or a CEL?
Old 05-25-2009 | 12:32 AM
im the fit's Avatar
i have weapon-r race headers, and a cel,i scanned the ob and it said bank 1 faulty
Old 05-25-2009 | 01:09 AM
BlueCell's Avatar
Have you cleaned it first? Pull it out and spray brake cleaner on it and then put it back in.
Old 05-25-2009 | 01:11 AM
im the fit's Avatar
I tried that and no luck.
Old 05-25-2009 | 11:55 AM
Daemione's Avatar
I've used o2 sensors on a couple cars from www.oxygensensors.com, they work great and are FAR less expensive than getting one from the dealer. Although fwiw, none of the ones I've ordered from them were wideband.
Their website doesn't seem to list anything for MY '07 or newer, but you could try contacting them directly. I'm sure the Fit shares a sensor with other models.
Old 05-25-2009 | 04:43 PM
bkrell's Avatar
Don't know about the Fit, but in my experience, newer Honda's are very picky about using Denso o2 sensors.
Old 05-26-2009 | 10:20 AM
im the fit's Avatar
bumpin it!!!
Old 05-26-2009 | 07:50 PM
im the fit's Avatar
bump bump!!
Old 05-31-2009 | 10:39 PM
bkrell's Avatar
I'd go stock, just in case. I had a 3 week odyssey with my CR-V b/c I ordered a couple of cheap universal sensors online. I tried Bosch, spliced everything correctly, and no worky. Got some no name aftermarket off eBay that were "claimed" to be OEM. They didn't work either. Broke down and got the Densos from Rockauto.com....and they worked right off. I'm a member at HondaSUV.com and everyone there warned me not to use universals or non-OEM. I blew them off b/c ever o2 sensor I'd ever replaced had been with a Bosch universal. I had to go back and apologize to them b/c they were right.
Again, that's a CR-V and not a Fit....but Hondas do, on occassion, seem to work best only with the OEM part. Much as I hate to say it....
rwjd
04-12-2024 12:54 PM
apexanimal
02-22-2016 12:51 PM
Clydesdale
05-04-2012 08:20 PM
XsteveedgeX
05-23-2010 04:23 PM
leonine
03-14-2009 11:51 PM
