Question: White Smoke during Engine Warm Up
Hi..
I own 2005 Honda Jazz mileage 28.000 KM. In the morning during engine warm up, white smoke comes from the exhaust pipe and soon dissapear several minutes after reaching optimum temp. (engine temp. light goes off). The white smoke smell rather like gasoline. Is this normal? Can anyone explain what causing this to happen?
Thank you...
Thank you...
Have to disagree with your here- Oil= blue smoke, fuel= black smoke, white= not smoke but steam. Has been that way for 100 years, but I am willing to grant that catalytic converters may have the effect of minor changes on these visual symptoms. Regardless, white is steam.
gaz = black
prestone = white
condensation = what you got... white
It's probably water vapor, since water and carbon dioxide are by far the two biggest byproducts of combustion. It smells like gas simply because the cat hasn't warmed up yet and therefore isn't working at it's ideal temperature. So what you're probably seeing is simply steam, as noted above. If it really is white "smoke", and is always there, it would suggest that you're buring coolant because of a head gasket or other problem, but that is highly unlikely based on what you've told us.
