Sponsored by:
Sponsored by: CARiD
engine surge..
Old 10-22-2007 | 03:29 PM
07fitsport's Avatar
engine surge..
07 fit sport us model...
wanted to find out if anyone else has this issue that when u are sitting stopped in drive with engine at idle and with the doors locked already and press the lock button or windows up with window all way up that the engine rev up about 200 to 300 rpms...wondering if it needs battery disconnected and the idle "reset" done or is it just a honda /fit issue that is normal...
Old 10-22-2007 | 03:43 PM
smatts's Avatar
Honda Fit Forums Moderator
Sounds normal, when you hold the window buttons down it draws a lot of current, and the engine needs to make a bit more power to the alternator I think is what's happening.
Old 10-22-2007 | 03:58 PM
doctordoom's Avatar
Supervillain
^agreed, same happens here
Old 10-22-2007 | 04:07 PM
smatts's Avatar
Yeah I get the same surges once in a while, I have a sub and amp, and when the fans turn on and I'm messing with the windows it happens. They are so short though I don't think it's an issue since they only spin up a few extra hundred rpm for a few seconds.
Old 10-23-2007 | 03:56 AM
claymore's Avatar
Normal operation the ELD (engine load detector) is sensing the increased load and automatically raises the engine idle speed to compensate for the extra electrical load.
Old 12-19-2007 | 03:14 PM
6speedmaster's Avatar
yeap all cars do it. Plus the Fits motor is rather small so it needs a lil help now and then
PhaseShiftDown
10-19-2014 04:33 PM
Bi(l)ljud
09-15-2013 07:26 AM
The Critic
04-20-2012 05:30 PM
tdj
07-21-2009 10:58 PM
cycoxtr
06-03-2008 02:13 AM
Quick Reply: engine surge..
