GAUGING: Interest 2007-2011 Honda Fit rear drum to 11" disc conversion
Old 12-22-2011 | 07:20 PM
MOTOMATT's Avatar
I talked with the people at Brake Kits - Performance Pads, Rotors, Calipers & Brake Upgrades and if we can get 6 people to buy this conversion we can get it for $675.00 before shipping.Its a complete bolt on kit.
I will start.
1. Motomatt.
2. ebisu8
Old 12-23-2011 | 02:21 AM
ohanahuichubbz's Avatar
if it can be 5 lug then im in!
Old 12-23-2011 | 11:11 AM
FitStir's Avatar
I'm 100% interested, but I want verification it will work for our USDM 09+ GE8's.
It was easier on the 07-08 GD3's because for them it was bolted on, but on our GE8's it's welded or something to that nature, which is why no one yet (that we know of) has done a rear disc conversion on the USDM GE8.
Old 12-23-2011 | 02:00 PM
MOTOMATT's Avatar
I was told 100% bolt on Please call them here's there # (If you have any questions, please call us at 602 323 2110 9am-5pm Mountain Time Monday-Friday. We are sometimes available on Saturday mornings as well.)
Old 12-26-2011 | 05:56 PM
ebisu8's Avatar
I'd be interested. Does anyone know if there is anything else needed such as the BB, MC, or proportion valve? Only reason I ask is I had to make these changes to my EK when I did the rear swap.
Put me down on the list, that's a good enough discount for me to do the conversion. Also, can we get blanks as opposed to cross-drilled/slotted as pictured? I'd really only want OEM blank rotors/OEM pads...
Old 12-26-2011 | 11:41 PM
Java^FiT's Avatar
I think I would be interested but can we get a full detailed list. I too thought that there was more to it for the newer GE's. Thanks!
Old 01-02-2012 | 08:17 PM
ebisu8's Avatar
We need more peeps!
Old 01-03-2012 | 11:11 AM
FitStir's Avatar
I'm sure they'll say it will fit, but I highly doubt it.
There was a thread last week (or the week before), which had a post with the parts diagram for the 2007 GD3 & the 09+ GE8, and it clearly showed our GE8's have the welded rear hub (?, not sure what the part is called), in the assembly as opposed to the 07 GD3's.
The fact that fastbrakes grouped the GD3's & GE8's together when clearly the parts are not interchangeble in this case makes me think it will not work.
If the kit works, I'm 100% interested in buying it.
Old 01-03-2012 | 11:17 AM
FitStir's Avatar
If you want 5 lugs, then why not do the CR-Z swap.
Old 01-03-2012 | 03:00 PM
MNfit's Avatar
i want this coversion, but I just dont have that kind of money right now
Old 01-03-2012 | 03:11 PM
ebisu8's Avatar
Is there a link for this? I can't find anything on it.
Old 01-03-2012 | 05:36 PM
FitStir's Avatar
There was mention of this in several threads, here's a great post in this thread ---> https://www.fitfreak.net/forums/2nd-...ml#post1037831
If you really want 5 lugs, I've read posts on here from oversea members who had their rotors redrilled to accept 5 lugs. Not sure how you feel about that, but that's another option.
Here's some threads referring to rear disc conversions on GE8's long read (and the info is buried since it's off topic to the thread) but great info in these threads:
---> https://www.fitfreak.net/forums/2nd-...brake-kit.html
also ---> https://www.fitfreak.net/forums/2nd-...tml#post925805
and a post from above thread regarding GE rear discs, and I stand corrected I said hub, but it's our GE8 rear spindles that are welded which makes a rear disc swap much more work that the GD's were (ie. not a direct bolt-on).
Originally Posted by cr4zy3lgato
well i think it might be a little easier with a GD3... i see why it such a PITA with a GE,
http://www.hondapartsnow.com/diagrams/large/rear-axle-467606.png
As you can see on this pic, part 2 (spindle) comes separately as the newer ones seem to be welded to rear axle...
I think that if the holes fit it would'nt be that hard, i know that it was done on the spoon fit, so it can be done!!! But i tought it would be easier tough... tought i only had to buy new drums
As far as I know the front brakes on GD's & GE's are interchangeable but because of the GE8's rear welded spindle the rears are not.
Old 01-03-2012 | 06:43 PM
ebisu8's Avatar
Thanks man. Since I have a GD3 I'll just stick with this kit since it's easy, plus I just bought a set of Regas in 4x100. I'll be content with that...
Old 01-03-2012 | 06:53 PM
MOTOMATT's Avatar
Thumbs up
Thanks for all the work, That is a bummer , I wanted bolt on.
Old 01-04-2012 | 03:37 PM
vinnymac's Avatar
I wonder if anyone here has these installed already. I'm just wonder'n if they are worth it on my non-track car.
Old 01-05-2012 | 08:24 PM
FitStir's Avatar
T1R had a rear disc conversion kit for the GD3's, AJ-R used to sell them. There's numerous threads/posts on GD3 conversions it shouldn't be that hard. This kit that was posted in this thread looks like it should work for the GD's, so I don't think any one should have any problem. Not sure if anyone installed it yet but there was mention of this in several threads. Also there are other options for the GD conversion (ie. parts from other Honda's, etc). As for the USDM GE8's it's not that easy.
Thank you as well for your efforts. I'm far from a mechanic, but I've read some of these threads several times over so I'm just sharing what I've learned from others on this forum. There was talk of a rear disc conversion in several threads, and the most viable option I believe (short of having some one unweld and convert the rear to accept bolts), it to import a complete rear trailing arm assembly from a market which has rear discs. So it's possible, but not sure how much that would cost. There might be other options, but I don't know.
Old 04-21-2012 | 03:20 AM
InSaNehb's Avatar
dead group buy?
Old 04-25-2012 | 11:53 AM
aptxgd3's Avatar
I'd be interested for sure, if it was still alive.
Old 05-16-2012 | 05:10 PM
JAZZdatFIT's Avatar
looks like an older post. but im interested. though would it also work for 2012 fit?
FitStir
24
10-15-2013 11:03 AM
johnnyHT
05-25-2012 05:43 AM
apexanimal
02-25-2010 01:58 AM
Spooling
07-04-2009 03:50 AM
Benggolf
Asia Fit Forums & Clubs
06-07-2009 04:43 PM
