SSR Fumoto Quick Drain Oil Valves
Old 03-15-2011 | 05:00 AM
speedstar-racing808's Avatar
Hey Guys,
Introducing the best way to change oil, the Engine Oil Drain Valve. Install our valve and you can drain your engine oil without tools and without mess. Just lift the lever of this solid brass ball valve and give it a quarter turn to open it. Return the lever to its original position and it locks closed, double sealed to prevent leakage. The Engine Oil Drain Valve is made of corrosion resistant forged brass and stainless steel. The ball valve design provides a straight flow for efficient drainage and a perfect seal when closed. Frozen drain plug and stripped threads are eliminated forever!!!
$30 - shipped
TypeOne08
06-06-2012 02:37 AM
5speedwonder
12-28-2010 10:55 PM
ironsheikh
07-15-2010 03:55 PM
08fithappy
02-19-2010 03:14 AM
gd3kamiwanaB
01-21-2009 10:34 PM
