Tpms questions
Tpms questions
Thinking about getting new shoes in 16x7 with 205/45. I'm ordering them from an online source, balanced/mounted(tire&wheel) and it includes the tpms sensor. Will I get that annoying deflated tire for Any reason whatsoever? Maybe due to different wheel/tire size variation in tire pressure
From Honda:
Honda will charge you for this, I'm not aware of an alternative way to calibrate the TPS.
All four tire pressure sensor IDs must be memorized to
the TPMS control unit whenever you do any of these
actions:
● Replace the TPMS control unit.
● Replace the tire pressure sensor.
● Substitute a known-good wheel with tire pressure
sensor.
actions:
sensor.
For those U.S. people that just simply ignore the TPMS light, does the light being on affect the on-board computer? ABS? Anything?
I plan to change tires/wheels twice a year (summer/winter) and don't want to have to reset it by the dealer every time!
The light is simply that, a light. Just a warning if they were in fact working showing you have lo pressure or somethings wrong so that you don't have a blowout at 60mph. i recommended leaving them in the wheels you use for spring/fall/summer and just ignore it if you put on a second set for winter.
personally itd be cheaper to get all seasons and let the magnificence of Honda guide you. or get chains lol
I just bought some Rota Slips on sunday that apparently came with TPMS sensors out of a 2009 GE and all I did was take of the stockers, slap the Rotas on my GD and now 5 days later still no TPMS idiot light.
GD's dont use the sensors that's why. only cars newer than 2008 were required to use this system by law in the US . you might as well sell the sensors for some extra dough if u ever replace the tires on those rota's and take them out then.
I confirmed this when I found a very very large pot hole on an otherwise seamless road at >50mph and shattered the one in my DF tire.
It is fuse #18, 7.5A for those who want to disable the light because you don't want to buy a set for your winter wheels, don't know which one it is in the GEs or what other systems it may be tied to..
Blackberry Goose
03-17-2011 08:32 AM
