wheel spacers
Man that's thin, all ya need the is the spacer disc. These are 5mm @ 65.50 H&R is a good co.
Acura/Honda H&R Wheel Spacers DRS 10mm 4x100 -- $119.95 $113.95 -- Fits most Acuras and Hondas with 4x100 Bolt Pattern. If you've ever seen a sleek, ...
www.allsprings.com/catalog/honda-fit-hr-wheel-spacers.htm - Cached - Similar
I used 25 and 15mm Ichiba hub centrics with studs and have had them on since after Christmas 2009 and all is good. Torqued to 80 ftlbs.
Thanks, I want one that thin because all I need is to push the rear rims out a bit so its more flush like the front. I haven't measured it but I'm guess I dont need any thing more then a 5mm spacer.
Im digging this thread up here and asking again. Has anyone ran spacers on the rear, on stock wheels, to flush like fronts. If so what mm are we looking for? When I get home I will try to guesstimeasure it
4 X H&R 5mm DRS hubcentric spacers (4x100, 56.1 hub (honda fit))
I paid 65 per 1 pair, and 10 bucks each to ship. so thats 150 minimum. Ill sell them to you for 100 bucks.
--Stock Front rims w/ Dunlop sr31s, Skunk2 Springs, Camber set at 0.17
--Pic is from tire to fender edge 3/4 inch
--Stock Rear Rims w/ Dunlop SR31s, Skunk2 Springs (1/2 coil cut), camber is 1.67
--Pic is from tire to fender gap 1 1/2 inch
Soooo 3/4 inch difference front to back on stocks with my camber Im wanting flush with stock fronts.
3/4 inch = 1.9 cm = 19mm
This will bring me closer, but camber will get me then.
kristoffer
10-16-2014 11:02 PM
