Aftermarket wheel lug nuts
I have been thinking of buying some nice chrome 12x1.5 lug nuts to go on my stock Fit GE mag wheels.
Some people are saying that they may not fit the wheel perfectly and cause a bit of out of balance feeling or vibration while driving.
Aftermarket lug nuts? M12x1.5 should fit perfectly...although for the stock wheels, you'll have to look for lug nuts with ball-shaped heads. Honda's OEM wheels have ball-shaped seats for the lug nuts.
Most aftermarket ones are tapered or cone-shaped as they're meant to be used with aftermarket wheels. The lug nut seats on those wheels are cone-shaped as well.
HTHs
HTHs
You can run aftermarket lugs on OEM wheels just IMO not the best thign to do. Due to the taper of OEM lugs compared to aftermarket ones they don't sit firmly on the wheel. You should just run some Honda wheel locks until you get some aftermarket wheels.
