205/50/15 on stock GD3
Anyone here have this set up?? Using 205/50/15 specs on the stock GD3 wheels. I'm only asking because i have a set of tires on some other rims i have and im going back to stock wheels and i dont want to lose such great tires since they are new.
yep i think ull be fine, these are the sizes u can run on stock rims 185/55-15, 195/50-15, 205/50-15, now since u got the last of the three offsets then ull be fine, actually ull be better than fine, i cant wait til my tires wear down so i can get a set of wider tires.
Sweet. I was just making sure if it would work or not. Its been awhile since i had stock wheels on and i didnt feel like buying new tires for rims if i have a set of tires already
EDIT:
Thanks for the help guys
EDIT:
205's killed my gas mileage
I've put 205/50/15's on mine, and it's really degraded my gas mileage. I was getting about 360-380 miles on a tank, and now i'm lucky to get 330. Kinda bummed about it.
Could this perceived decrease be partially due to the change in actual miles traveled/vs what my odometer is reading?
It can be a trade off with wider tires. If you go wider tires get lgihter wheels. Stock tires go with heavier wheels. Try to always stick with the same weight as the stock tire/wheel combo.
andre181
09-29-2015 08:45 PM
bigbacon
07-28-2015 10:23 AM
