Will i have rubbing problems? Enkei RPF1's
Looking into ordering some Enkei RPF1's in 15x7.0 with a 41 offset. Will i have any problems being as im lowered with Skunk2 springs? If i wont have too many problems what would be the best sized tires?
I am using 195-55-15s on mine..... My car is at stock height and I had very slight rubbing on the front when cornering over a bumpy road surface but squeezing the plastic inner fender liner by hand fixed it.
I have RPF1s 15x7 +35 dropped on skunk2 springs with the stock tires. I did the fender liner mod before I got the wheels on so I couldnt tell you what exactly that helped with. I rub on large dips/bumps and smaller ones when the wheel is turned. I just installed camber bolts tonight and I should rub even less than I did before. I am currently home at the moment so I dont know how it will do in areas that rubbing usually occured. You should be fine with the higher offset
The extra width of the tire is what is causing the rubbing. 10mm extra seems minute, but that's all it'll take.
when i was on my ssr's i didnt rub on 195 50's but now that im on 205 50's with my slipstreams i rub on hard dips and turns... mind you my fenders are rolled and fender liners tucked.. 205's feeeeeel so much better but look chunky..
