+32 offset question and 205/50/16 tire question
Old 06-01-2009, 02:21 PM
artieman's Avatar
my 2 cents....
i run 205/45-16 on 16x7 wheel with 32 offset and it clears...
Old 06-02-2009, 11:37 AM
GD3_Wagoon's Avatar
great debate danielg and mahout, i knew the basics of wheel/tire fitment but the information the both of you left in this thread helped me understand it on a mathmatical level.
a little perspective for the OP. i run a 15x7 +40 rim with 205/50/15 tires, i'm on skunk2 pro-c coilovers with about a 2.5" drop up front and 2" drop in the rear. i do experience light rubbing on hard turns and drop-offs. however, i rub A LOT when there are people in the back seats.
i pulled back the fender lining and it helped a bit up front. i think with a light fender pinch i'll be clear of rubbing on all four corners
Old 06-03-2009, 11:14 PM
tougerunner86's Avatar
I have 15x7 +32 offset and stock 195's on my car, lowered on eibach sportline springs (the not so aggressive set) and they rub every dip I hit on the interstate. Not that you shouldn't do it though because we need more fits with lower offsets!!! haha. But a 6 inch wide wheel with a +32 is not going to stick out as much as a 7" so you may have less problems. I dunno.
Old 06-04-2009, 12:16 AM
danger69's Avatar
Thanks tougerunner86 for your experience. I will not be dropped super low or even to normal low. I will be getting the swift springs later on which will just give me a minor lowered stance.
Old 06-04-2009, 02:39 AM
mzamike's Avatar
danger69, I am running a similar wheel setup to what you're asking about. Mine however are 15x6.5 +32 with 195/50's. I'm dropped on Progress springs which have a subtle drop just as the Swift springs do (if i remember correctly) and i do not rub whatsoever. If I were you i would opt for 195/50's to be pretty safe but as i've read on the forum, for some reason you really can't tell with all fit's. good luck.
ds62987
12-15-2008 09:36 PM
AtticusFit
06-21-2008 12:55 AM
trancedsailor
06-18-2008 07:16 PM
kptrulee
05-03-2008 03:54 PM
korky
04-22-2008 05:24 PM
Quick Reply: +32 offset question and 205/50/16 tire question
