18's x 8 +32 offset...will they fit!?!?! and what tires would you recommend
i was pondering if the 18's x 8 wheel with +32 offset will fit on the GD3 fit? If it does, what tires would you guys recommend??? btw they are the sportmax 504 wheels...
thanks
thanks
dang 18's....think those might to big but if you like them then i think 215-205/30-35 tire size would fit. you might be rubbing the inside, oh and i recomend not putting anyone in the back cause they will rub on bumps and dips.
The design of the spokes has more of an impact on whether or not a wheel clears the caliper.
Offset has very little to do with the fitment of the wheel dish over the caliper. Offset merely sets the relationship between the outer and inner wheel rim edges compared to the hub face.
The dish must be deep enough to clear the calipers. If the dish were flat there is no hope of clearing the caliper as calipers extend an inch or so further out than the hub face. There is a wide variety in the dish shape which is why even though the BC and offset are OK the wheel may not fit. The hub bore also must be matched as well.
And no; 32 mm offset is too much as well as the extra weight of 18" tires will stomp on your acceleration and mpg numbers.
If you are willing to do bodywork then you can go for it but be prepared for a drop even with such a tire as 205/35x18 even if it exists.
Goettler
60
06-29-2016 10:41 PM
