Biggest wheels possible?
#41
the larger the wheel is the larger the tire will be, you can change it buy getting a lower profile tire but it wont really matter unless you go larger than the overall diameter of what the factory specifies, plus you will loose some of the space you have to work with buy lowering the car plus, the amount of travel the suspension has to. witch is why some roll, pull fenders, trim linings and tabs, but the whole point is if you want to run a wheel thats larger than average, or larger than what people are runnig then you will have to do some work to get them to fit, instead of waiting for someone else to tell you what will work
Just so it's clear, a 205/40x17 tire is 23.45" in diameter and a 205/60x15 is 24.68" in diameter so the larger the wheel does not mean the tire is larger. Only the tire size matters. And offset:
And you have to consider where the tire is located in reference to the hub face. Move it too far in or out and chances of getting interference is increased just as using a bigger tire. Hence offset matters too.
#44
That was my hole point I can calculate tire sizes and all that hell I could just go the the rim shop and physically measure the tire size I want to use against what I have with a tape measure. but will It get the wheels I want to run to fit right ??????? NO. And since I work at a body shop I could just put in the work and time to get some low offset wheels to work when nobody else says they can which to me is the fun in modifying your car
#45
Originally Posted by [B
Hence offset matters too[/B].
here11
15
06-20-2010 01:40 PM
prim3tim3
04-08-2010 03:56 PM
