15" questions
15" questions
just bought a 08 base and im trying to find out what the widest 15 and the biggest widest tire that will fit stock suspension without rubbing and wich offset, looking to be flush with the fender
Good question roflmayorga. I've look for an to this question too. I'm guessing that wheels for either the Standard or the Sport will be the same. Correct? Also, maybe someone can explain to me understand wheel offset.
The 15" wheels are the same for Base and Sport. Base comes with 14"s unless you check the option box for 15"s. Offset confuses me too, I think tirerack or discounttiredirect.com have explanations on all things tire. Camber, caster, toe, offset, etc.
7" +40mm offset is the max you can go without rubbing given that you
run 195/50/15 all season tires.
kurisux92
12-15-2011 10:08 PM
ssolty
11-25-2007 11:42 PM
