AWII Snowflakes
AWII Snowflakes
anybody know the bolt pattern on the 1st gen MR2's?
a friend of mine on mr2oc.com has a set of snowflakes that he wants to get rid of. before i drive out to Valencia, i'd like to know if these will even fit. thanks in advance
(the 1991 MR2 had 5x4.5 BC BTW and the stock Fit has 55mm offset)
You will have to check for clearance around the calipers and trailing links and for the hub bore being 64 mm or slightly larger.You will want the backspace to be close to 5" if yopu don't want bearing concerns but it seems that the MR2 wheel was 14x6 or 15x6.
good luck. Let us know what you find. I know a few junkyards I want to peruse.
linnboi
07-20-2012 12:43 AM
