need opinions from the wheel whores!
if not, ray go for it, f`in sex. be the first 9"wideeee
Posts in the NUUDE
Psssh, Ill do 16x10's. FIND EM!
And Jason, I didnt know you had a DSM? I know a good amount about them. My first engine swap was a 91 6bolt into a 93 Mirage Coupe Sedan.
Wwoooo! That car flew. Big 16G on 22psi, cheap tune on a AFC, 110oct.
GOTDAMN!
GOTDAMN!
Mine was a 1991 Eagle Talon AWD with a built bottom end, Ross Racing pistons .030" over 9.1:1 comp, Eagle 4130 rods, balanced crank, ARP bolts and studs, MLS head gasket, BJ's Stage 4 head with 1mm oversized valves, Comp 284 cams, ported 2G exhaust mani, GT30R dual ball bearing turbo, 3" turbo back, TRE/Shep stage 4 tranny with ACT 2600# and a VCE, Driveshaft shop axles, Wilwood 6 piston calipers, 13.25" rotors, D2 coilovers, Walbro 255lph HP, 720cc injectors, AEM EMS with wideband O2, on and on and on, you get the idea! EVERYTHING!!!
20lbs of boost, 20 degrees advance, on 93 octane made about 485whp and ran 1.50 60' time and close to a flat 11 in the 1/4 with 18" Yok ES100s. Never got around to a race tune on C16, but I would have shot for no less than 600whp at 35psi.
Vid of me racing a caged/gutted LS1 F-bod on slicks.
MySpaceTV Videos: My Talon AWD Turbo vs 2000 Firebird LS1 by Jay Dog Photog
get df210s and run a reverse staggered set up to match the spring's reverse rake stance
19x8s up front (dont' worry you wont rub) and 15x7s in the rear (dont worry there wont be a big gap)
but that's just me
but that's just me
#33
Posts in the NUUDE
DAMN!! Nice, Jason
They aint staggered though. And honestly, I bet they found 2 Speed3's with a +30mm offset and 2 with a +40mm offsets.
*LAUGHS*
Then they were advertised as a staggered set-up.
He showed me the link a while ago... Hes still waiting?
Id be nervous....
James, if youre still debating or waiting to sell the RG's.... Good luck.
Im serious that these wheels will not last long. Im surprised that theyre still on the site.
Originally Posted by fit_love
lol someones waiting for them
*LAUGHS*
Id be nervous....
#35
If I didn't already order wheels I would have scooped these up. You should throw them on Honda Tech. Probably sell faster even w/ all the lowballers.
#37
I like the RE30's a lot. I was thinking of some 15x6JJ +48:
$314.43ea at Nengun Performance:
Rays Engineering - VOLK Racing - RE30 - Nengun Performance
Still a buttload of money for a Fit, though.
#39
RAY,
Forgive my ignorance . . .what kind of wheels are those in the pic above on your red fit? I'm not wanting to alter my height (base model fit on 14" steelies), but I am looking for some new wheels. How would ones similar to yours work fro me?
Thanks in advance for the info
Tbird
Tbird
