Fat a$$ 15's
Lets look at 15x7 rims.
195/50-15 will fit fine but the width of the tire at the rim will look wider than the tread surface width because the tire is a bit narrower vs a wider tire. This technique can be used when going with a wider rim and trying to squeeze a tire in the wheel well on a lowered car. For example 205/50-15 or even 195/55-15 using 15x8 rim.
205/50-15 might look more balanced like it was meant to fit the 7" wide rim.
225/45-15 tires look a little wide on the 7" rim by comparison but it's still pretty good in my opinion.
Generally you try not to put an extra wide street tire on a more narrow rim- this can increase tramlining and noise when driving on grooved highway surfaces.
well, MINI-Fit, since you mentioned my setup, my setup is not for
cornering, it is for daily driving and slightly more aggressive gear ratio
than stock for straightline. that was wat i was after.
Your setup would be good both for cornering and street driving. The Ziex 912 is more street friendly true but still has enough grip (yours are newish).
Smaller diameter tire diameter good for lowered gearing but with a little speedo error.
When speedometer reads 60mph (96.6km/h) actual speed will be 58.2mph (93.7km/h): 3% slower.
I ran the same sized wheels and tires on both my Fit and MINI. Worked pretty well. But the tires were Bridgestone RE-01R so it was more grippy and quite good on comfort.
If your suspension is more aggressive then you can corner better. Otherwise like you mentioned go after softer rubber then max out on the negative camber (tire wear isn't that bad up to about -2 degrees).
205/50 Azenis or Hankook RS. The Victoracers V710 are GREAT tires, but make no mistake, they are 50-60 rated tires. The Azenis are 200 rated....
So they'll last only a few thousand miles....
good luck
-bix
good luck
-bix
Lexani Performance Tires
The Lexani N3000 is an ultra high performance (UHP) tire designed for superior performance without sacrificing ride quality. With fitments for the curve-carving tuner to the street cruising sedan, the Lexani N3000 is the tire for your performance car.
Available in low profile sizes for 17” through 24” sizes, the Lexani N3000 is the ultimate in performance and style.
Lexani N3000 Features
- Silica based tread compound offers superior high-speed durability, lower rolling resistance and increased traction.
- Large center tread block delivers high-speed stability and a smooth ride by absorbing impacts from imperfections in the pavement.
- Large tread blocks on the edge of the tire improve cornering by resisting lateral force, keeping more of the tire on the pavement. This also improves performance “at the edge” providing a clear feel for the limits of adhesion.
- Single wire bead construction offers improved strength, ride comfort and steering stability.
- Aggressive V-shaped tread pattern offers excellent water dissipation for wet traction.
Uniform Tire Quality Grade (UTQG) Ratings
Treadwear 340
Wet Traction AA
Temperature A
Do you have stock springs? If you do you might rub because that heavy load in the back might make you rub in the back when you hit bumps. Aftermarket springs are stiffer so as long as there is enough clearence they usually won't rub unless you have tons of weight in the car or hit a bump really really hard.
I rubbed bad with stock suspension and these tires with a +42 offset
I switched wheels for a +45 which was ok, but then I lowered on GF210's (only about an inch overall) and it rubbed again.
Adam_Melton
111
04-16-2023 10:12 PM
