What tires should i run on my mugen wheels
What size tires should I run on my Mugen NR Mirror Face Wheels 15x6.5, 4x100 +45? I want the wheel tire combination to be the same circumference as the stock 15 inch wheels with the Dunlop 195/55-15 tires. Does anyone know?
If you want stock and both wheels are the same diameter then use the stock tires or a tire with better performance in the same size as stock. But I would prolly try a 195-50-15 if they make tires in that size I really cant say right at this moment but just a thought. But if both are 15's then stock tire's should fit and save you a couple dollars right now
I think with any Dunlop tire from Tirerack right now
Those Direzza's are sweet
here is a 195/50/15, only 61$ each and you still get a shuffle. Now I can't remember what the stock size is, a 50 or 55 series?
Dunlop Direzza DZ101
Thanks for the response. Do you know if the 195/50/15’s you’re running have changed your gearing at all, or the accuracy of your speedometer? Also, do you have any other Mugen mods on your car? I was looking at the strut tower bar for mine.
If you want a shorter sidewall but wanna stay as close to a stock rolling diameter as possible, you might wanna try looking at a 205/50-15.
im running a 195/50 on my mirror face NR. i also have the tower bar and ventilated visors as well! i have yet to receive my roof spoiler like the one on the cover of this months honda tuning...
Klasse Act
04-28-2010 10:56 PM
geoff2005
02-03-2010 07:47 PM
