I Am Freaking Rubbing!
Okay....
I just put on some Rota Slipstreams 16X7 with a 40 offest. The tire is 205/45/16 and i am rubbing on the drivers rear fender when someone is sitting in the back. Pretty badly. I was told by many that they have their car lowered and only occasionally rub with the same setup I have... Any ideas?
dude, your going to rub, im rubbing on df210 with 195/55/15, on 38 offset 15x7, i think i have to go to a 195/50 maybe, anybody got any thought on this.
You can prove me wrong...but when I had that setup with weight in the rear...it would rub. The fender will rub/cut into the tire a little with all that weight in the rear. It's just has no where else to go unless you have more cmaber.
