The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!)
#481
wheels slightly out the fender by a few mm. for the 7.5 a low 30+ is manageable, depending on how you want to do it really. how to fit it isnt much of a problem, rolling fender, fender line tuck and all that. 15x7.5 is rare combo, but i heard bbs wheels can modified their offset anytime.
#485
03
STTich: it is Awesome. that wheels used to be mine. Peejay both it from me and i replace it with Work equip01. whats your offset on you 01?mine is 15 x 7 +38. now my equip 01 is 15 x 7.5 +39
#489
@solbrothers: Thanks Bro.
@Fit4Trav: The 01 that i have is a deep rim design. not the standard so the problem is the spokes is hitting the caliper so im running a 3/8" spacer on it. so ill be installing a longer stud bolts and will be putting a 1/2" spacer. so ill update the pictures.
#490
Wheel: work equip 01
Offset: +39mm
Color: polish
Tire: Advan neova AD07
Lowered?: Yes
If Yes, What Setup?: Tein basic wagon coilovers
lugs: Work racingLugs
Front Rubbing: Nope
Rear Rubbing: Nope
Comments: i add 3/8'" spacer in front to prevent,rim spokes hitting the caliper. since i used Tein Coil overs my rubbing was gone. it was recommended by tein.
Offset: +39mm
Color: polish
Lowered?: Yes
Front Rubbing: Nope
Rear Rubbing: Nope
