15x7 +38 with df210???
yeah thats what somebdy else said but is it the low offset of the wheels or the springs because i dont think the df210 rubs on factory sport wheel and tire right, so must be the wheel. the reason is i want two sets of wheels cause i bored with wheels quick,that way i can swap them out evey month or so, my first choice shouldnt be a problem almost the same as you had, konigs helium black red but in 15, my second choice is the drag dr20, i could only find in +38, i think the konigs are +40, so just 2mm makes that much difference, maybe a different size tire on the drags would help like a 50 instead of 55?
u might be ok with a 195 50 15 with the offset. my konigs rubbed cuz i had 205 45 16. its not bad but when u hit a dip it rubs on the little screw on the top of ur fender wall. its just annoying for me.
Socialvegetable
07-29-2011 03:14 AM
aallbbeerrtttttt
11-19-2007 10:29 AM
