gram lights 57s
gram lights 57s
i think i found the rim i want but i am not educated on rims or wheel s at all...so i was wondering if somone can give me some help... i am looking for the biggest rim that i can fit with out rubbing and a daily driver car... i know that gram light makes the rims i like the the bolt pattern for the fit but what offset and rims size is best for what i need thanks... specs below
Gram Lights: Pride of Light Weight!
Good choice of wheels. I was planning on getting these in bronze before I got my cups. you wanna run the Biggest??? ehh.... not my cup of tea... but I believe someone on here is running 18's. Not sure what his offset is, but I'm sure the closer to stock you are, the safer you will be from rubbing. From what I see from the "biggest selection", I believe that you'll be able to run the 17x7.5/+40/4x100 or the 18x7.5/+40/4x100.
Also keep in mind that getting bigger wheels will significantly decrease your acceleration, especially in this car with such little power to start with.
i dont want 18 or anything up there but i herd small was better for the fit and i just dont want to roll on 13 is 16 good or to big????i think the smallest size for that rim is a 14 ... ok so 16 being the biggest that i want would i rub or lose performance???
Well you did say:
sounded like you were looking for 22's if they would fit.
Anyhow 15's or 16's would be good and nothing wider then 7.5in. Personally I'd go with 15'sbut that's just me. The stock off set is +55, so just base your decision on the wheels who's offset is cloest to stock.
Also take into account that if you want the "flush look", lower offset is a must and may cause rubbing. If you don't care for the your wheels to look flush to your fenders, you should have all the info you need to get your wheels.
Good luck!
Good luck!
GE-DZ149
07-20-2012 12:10 AM
