For those who say LOW OFFSET wheels wont work on a Fit
#44
With stiffer springs, I could have done all kinds of crazy wheel/tire combos without rubbing. The main problem is that a lot of guys have off the shelf lowering springs like Tanabe, Eibach, Skunk2, Vogtland, etc.
Those lowering springs are great for daily driving and looks, but when it comes to bumps and cornering, the body moves around and leans and compresses on the springs, and they compress almost like a stock spring. Bump up the spring rates with some aftermarket coilovers with linear spring rates, and that problem should go away.
Rubbing mostly occurs on the rear with 1 or more passenger, the fronts occasionally on bumps and dips.
I already got a new wheel/tire setup, 17x7.0 +43 Enkei RPF-1 wrapped in 205/40/17 Yokohama Parada Spec 2 tires. Surprisingly, these wheels don't rub at all in the rear, only rub in the front when I come across a dip or something.
#46
JBlood hood and new wheels, eh? What kind are they? For some reason, I keep thinking JLine but I highly doubt that, haha. Only 86 I knew that even came close to such a crazy body kit was the TRD wide body. He then sold it to Papa Gush and they just took off the kit and well... that was that.
ZIP TIESSSSSSS!
ZIP TIESSSSSSS!
anyways...back to the fit...
#49
it might. i know i had 17x7 with 25 off and it rubbed in the back a little but only on the drivers side
#52
From that. Use this to get an idea about fitment
Wheel Offset Calculator
NOW: if you use wider rims, then its a total different ball game, as in offset, stretching tires and etc....
#56
hm funny, because mine 15x7 +25 is rubbing like no tomorow, even when i use 185/55, first time with 195/50 thats was worst. yea I rolled and trim off the bumper join
#59
the rear I didn't heat it up...and I actually rolled it too much but I doesn't look wrinkled if you look closely(in person)...I think it's the angle of the photo. it's just pushed out on the top and the bumper is flat so it looks funny. i'll be fixing it tomorrow or day after when I get more time. I think I could of gotten a way without rolling it since the tire is stretched on a 8j unless I lower it more.
sitting on df210 on the rear and swift up front so it's an even 1.3 drop all around.
planning to put the df210 on the front and cutting a coil off a coil on the rear to make it sit a little lower.
