wheel stud problem
Old 02-13-2007 | 02:18 AM
boyetssilverfit's Avatar
wheel stud problem
i put wheel spacer on my new wheels(rota jspl 15 x 6.5 )+38 offset,it clear the caliper but its very very close,so i decide to put wheel spacer,its a 5 mm spacer,when im about to tighten it one of the lugnuts wont fit in,and when check it the thread on that stud was messed up,can you guys please help me on fixing this problem.im planning to take out the wheel spacer if i have no choice or put in longer stud if i have to,the question is how am i gonna take out the stud/studs if i decided to put a new one.
Old 02-13-2007 | 02:37 AM
rcantu's Avatar
i think you can try a wheel shop or a mechanic. you can roll on 3 lugs if you have to just don't be driving hard or fast on the freeways to get there.
Old 02-13-2007 | 07:41 PM
JDMish's Avatar
Sounds like you have cross-threaded the stud. not a huge deal but you will need it replaced. You can run on 3 of the 4 studs no problem, just don't bag the car. the wheels will probably be really close to the caliper but it will never hit so the spacer is not needed.
Old 02-13-2007 | 09:24 PM
smeister's Avatar
Yeah you will need to pop out the stud and get a new one put in. If you get it done at the honda dealer they will charge you about $100-150 so best to look elsewhere.
Rollerboots666
04-10-2014 01:02 AM
lji
02-11-2014 07:30 PM
Vanct
04-12-2011 05:18 PM
phoenity
12-04-2010 03:36 PM
