AirREX Air Ride Suspension now for Fit!
#32
I'll just post up the full kit price here since there seems to be a lot of interest
The price for the front and rear air struts is $1950 with shipping. You can order in bellow or sleeve type. The sleeves allow you to go lower because they are a bit thinner in design.
Here is a list of typical components that you would need to complete the full kit (all prices include shipping)
VIAIR 380 Compressor - $189
4 Gal Aluminum Tank - $99
Water Trap - $35
2 Air Switches - $60
Pressure Switch 200 psi - $27
Air Line, compression fitting, and wiring kit - free
Dakota Digital Gauge Round w/ Chrome bezel. Blue LED readout. With (3) 400psi Senders - $324
The advantage to this kit is that you don't need to purchase all of the required components in a full kit, like AirRunner where you have to purchase the whole kit. So it's up to you what you want to do on the air management side. We can get all of the components needed, but this makes it better because you can specify individual parts to make your kit one-off.
But, if you wanted to purchase the whole kit with everything listed above, it comes to $2684 with shipping.
Let me know if you have any specific questions. The kits take about 3-4 weeks to have made.
Water Trap - $35
#35
are you sure it's not the other way around? I thought bellow type allows you to go lower than sleeves.
#36
I was told by AirREX that the sleeve allow for a lower setup because it allows more room for the tires.
Please let me know if you have any questions!
Thank you,
Spencer
#39
Thanks for the message.
Everything is pre-assembled in the box and all you need to do is hook up the lines and install the air struts that are plug and play for your existing suspension setup.
It should fit the trunk of the fit - its dimensions are 30” X 12” X 10.5” to fit even the smallest of cars. The composite wood casing is fully carpeted in gray to match most interiors and features a stylish smoked acrylic window.
