DIY Liquid Urethane - The Poor Mans Motor Mount/Torque Rod /Front Engine Roll Stop
Old 05-21-2018 | 04:05 PM
evilchargerfan's Avatar
Post DIY Liquid Urethane - The Poor Mans Motor Mount/Torque Rod /Front Engine Roll Stop
https://www.fitfreak.net/forums/3rd-...ml#post1400985
My past cars have always had upgrades to engine mounts, tranny mounts, pitch stop mount, etc. This car will be no exception. I didnt like the price of the Hasport Rear Motor Mount/BeatRush Front Engine Roll Stop, so I decided to go the DIY path.
Pouring the liquid is insanely easy, plenty of youtube vids on how to do it. Biggest thing to remember is, keep the mount level and do a good job taping or else you'll leak everywhere.
For those who care, I went with the 80A High Performance Durometer:
DIY Liquid Urethane Engine and Motor Mount Inserts
Old 05-21-2018 | 04:07 PM
Posting this, so I can view later:
Please note, the liquid takes 5 days to cure under normal temps. I have no way of keeping the mount at 150 degrees F, otherwise it would cure in just 24 hours
Old 05-21-2018 | 05:02 PM
domoMKIV's Avatar
Thanks for the reminder that I need to do this before I NEED to do this. Nicely done!
Old 06-11-2018 | 03:38 PM
Finally got around to installing that darn Torque Rod. Per a few posts ago ... followed the repair manual and torqued the bolts to 61lb and 69lbs and in the order specified. One thing they dont mention is, the new Torque Rod going in, may not align right up on first try .... but its not hard at all, to use 1 hand and simply nudge the motor in the direction you need it to move
Impressions ..... this is a MUST DO. For those of you on the fence.... DO IT NOW and stop thinking about it. The car "feels" faster. Down shifts feel more crisp, the car over all exhibits less slop and wobble, the car feels more "sporty". NVH slightly increased .... like during idle and when AC is on .... but it is most definitely worth it!
I am considering taking my OEM Torque Rod and torching out ALL of the rubber, and doing a full re fill using the hard liquid urethane stuff. Example:
Old 09-27-2019 | 05:19 PM
UPDATE:
Vtec must have kicked in ...
https://photos.app.goo.gl/rXxWMxSJcHPPTpnR9
Old 09-27-2019 | 05:27 PM
2Rismo2's Avatar
I didn't realize the L15B1 was such a torque monster!
Old 09-27-2019 | 05:36 PM
Z062FIT's Avatar
What is the other one in the pic. I see the one you filled. and then another one that is not filled. But they're not exactly the same. From a different Fit???
Old 09-27-2019 | 05:40 PM
one is oem, one is aftermarket (the busted one)
Old 09-27-2019 | 05:45 PM
Z062FIT's Avatar
So, you urethane filled an aftermarket one? I also thought mine was ribbed on the side (for pleasure)... BTdubbs and not to hijack, I am going to try some wrapping this weekend (no microphone), so HMu on google hangouts with any advice. cheers, d
Old 09-28-2019 | 06:51 PM
marmaladedad's Avatar
So when it snapped/broke, did the car become Lexus-like in the NVH department?
What have you got planned next?
Old 09-28-2019 | 06:55 PM
it was loud a clangy. thankful it broke close to home.... so i was able to drive slow
what's next?
Old 09-28-2019 | 07:28 PM
what's next?
oooh, shiny!
De36
04-25-2018 01:51 PM
KV43
03-03-2015 04:29 AM
allmotormark
10-10-2014 02:16 PM
lcq4blackstar
07-13-2011 07:04 PM
CuTeBoi
05-04-2011 07:57 PM
