Which LSD
#203
#205
TPColgett, do you track your car?
On July 19th there is 3 balls racing HPDE at waterford hills raceway, I am thinking to take my Fit, although I already signed up for the Boss 302
My problem with the Fit is, it just does not feel confidence inspiring when it comes to high speed turns despite the mods I already did.
I don't know what you think
#208
#210
VERY true... I still do my best to use as little brakes as possible for AutoX though... The Fit does not have any low end grunt to speak of, so if you brake too hard (anything below 3K RPM) you loose ALL the power band.
I went with Hawk HP+ pads for 2 main reasons. 1 I know they will survive/suffice for a simple spirited track day like an HPDE. 2 they have excellent initial bite, and I tend to brake late and hard
#211
late braker here also. I would take out a few cones if the brakes were left alone. But, the Fit does not turn when on the brakes.
#212
+1 on that. Now I just tap them to front load the weight for better grip and get the rear to start stepping out
junktea1
12-07-2009 10:43 AM
spoonek4
23
01-31-2007 09:58 AM
