need to do brakes, what should i do?
Hey guys. need to do the brakes in my fit finally. Im an aggressive driver and like to have fun in the car. go to track days occasionally but mostly just a daily car for me. like i said i drive aggressively. what should i do for brakes? just keep it oem or what?
+1 hawk pads and stainless lines.
make sure you get teh basic hawk pads..the higher end ones are meant specifically for race applications and need to be heated up to work properly. they will squeal and not work as well if they arent.
Were you having trouble slowing before? Brake fade? Spongy feel? Aggressive driving doesn't kill pads. So you're lumped in the aggressive braking catagory! I drive aggressive and have 85k on original pads and rotors. Hawk pads are overkill. Good quality but if " because racecar" look into a caliper upgrade.
If you're a brake hard, brake often-type aggressive driver, then checking and changing fluids often would be a good idea... Just my take... with a stock set-up.
setter11
15
09-11-2009 06:49 PM
Beerman182
06-27-2005 08:22 AM
