Who want's to own the first set of Fortune Auto 500 series for a FIT (GD)?
I am currently working with Fortune-Auto USA on releasing their 500 series coilovers for the USDM FIT, first for the GD and shortly after the GE. They make them for the JDM FIT already but need a USDM FIT to do some measuring and testing on the USDM chasis. They are located just outside of Richmond, Va (23139 zip code) and would need a full day or 2 of test fitting and measuring with the vehicle. Whoever does decide and or is chosen to do this will receive a significant discount on the first set. Someone local is preferred due to the time frame. Please PM me for more details if you are interested!
A little history on Fortune-Auto:
For over 2 decades Fortune Auto MFG corp has been producing shocks made from the highest quality raw materials and machined to aerospace tolerances. In 2005, Fortune Auto MFG corp introduced to the world the first affordable digressive monotube shock absorber. They have taken affordable shock absorber technology one step further by offering full customization to their customers. All Fortune Auto shocks sold in North America can be built to order with custom spring rates, custom shock valving and full rebuild capabilities. Fortune Auto is the premier manufacturer of Asian coilovers in the world. They invite you to experience the unrivaled service and superior suspension technology of Fortune Auto.
All Fortune Auto shock absorbers incorporate the following features:
Fortune-Auto 500 Series Coilover System
Fortune Auto 500 Series Coilover Specs
DIGRESSIVE* All Fortune Auto shocks use a superior DIGRESSIVE piston. This technology allows for stiff, progressive (linear) damping at low stroke speeds. This helps to control vehicle body motion like roll, dive and squat. However at fast stroke speeds (i.e. high speed bumps) the suspension is kept supple in response to bumps and irregularities in the road.
***Every Fortune Auto coilover is extensively dyno tested and matched with in specifications to insure a consistent and uniform set of coilovers. This rigorous testing has earned them their ISO certification.
Furthermore they incorporate features only found on their coilovers such as seamless stainless steel monotubes, forged lower mounts & proprietary nitrogen gas chambers.
Fortune Auto 500 Series DYNO Sheet:
Check us out on Facebook and Twitter!
Email: aaron@shopformfresh.com
Phone: 1-877-527-2261
Website: (under construction) www.shopformfresh.com
- Custom rates and valving
- Over-sized 57mm construction
- Rebuilds and re-valving at our USA facility
- USA tech support
- 30 way adjustability
- Anodized shock bodies for superior corrosion resistance
- Height adjustment independent of preload
- ISO certification
- All coilovers are DYNO TESTED
- Dyno tested***
- Mono-tube shock design
- IP synthetic 5w or 10w shock oil (prevents cavitation and promotes superior heat dissipation)
- Stainless steel body / piston
- 30-way adjustable dampers
- Pillowball mounts
- Forged aluminum locking collars
- Dust boots on all pistons
- Digressive* 50mm piston-57mm piston housing (beyond the industry standard of 44-47mm)
- Anodized aluminum camber plates** on front upper-mounts
- Fully anodized body
- 1 year Manufacturer's Warranty
- ISO 9002 certification
GD3 GeGe~
02-01-2019 04:32 AM
ikutoisahobo
03-18-2014 06:35 PM
richard612
07-06-2010 08:49 AM
