WilWood BBK or Black Label Racing kit (JHPusa)?
#43
u can us any Civic/Interga 262mm brake kit. but you'll need Special brake lines to work with some BBK. some kits allow for the stock banjo bolt. some like the Wilwoods use a fitting. Brake Kits - Performance Pads, Rotors, Calipers & Brake Upgrades hooked it up on some SS lines with the Stock/ Wilwood fittings. the fit has a weird block like piece at the Hard line/ Rubber line point.
#44
Thanks to Brake Kits - Performance Pads, Rotors, Calipers & Brake Upgrades for the lines, they have a lot of GD3 brake stuff. they are working on GE stuff aswell.
Ill post pics of the kit 2morrow.
#47
Wilwood Fit Kits
#49
it should, it says it will even fit some 15's which is sketchy i think, worst case ull need like a 5mm spacer but give them a call and ask, they will def answer any question you have, its what theyre there for.
#50
I run wilwoods, the 6 pistons though. It can fit 16's on that setup. I bought the Integra/Civic kit, it's all the same. My dealer gave me the right fitting for the ss lines. I think when they said 15's thats with the smaller rotor size, I'm not sure since I run the 12.2 inch and there is an 11 inch rotor setup. I have a ton of clearance in the front for wheels, I run a +32 17 inch rims and have too much space where I can get a lip wheel. Rear setup, that's a different story.
Nighthawk_GD3
08-15-2009 08:06 AM
F'it_ImFromTx
02-22-2008 05:27 PM
