Springs that won't lower the car
Can anyone think of aftermarket springs that will not lower the height of the car. I have a 08 Fit Sport and I would like to stiffen up the ride but don't want to lower it. Any suggestions would be great. I've been looking around and the closest thing I can find is a coil over kit that can be limited to a .8 inch drop.
I can't think of one good reason to raise the spring rate if you're not lowering your fit. The stock rates are plenty high. As Redrumm said, you're better off just upgrading the shocks or if you want to balance the car a little better you could just install a progress rear sway bar. That's what I did and it was a worth while upgrade for not much dough.
TEIN High-Tech springs drop about 1" too...these are gold-painted instead of the green S.Tech springs which drop lower.
Swifts, however, offer the smallest drop.
Xtina
02-12-2017 01:04 PM
danger69
22
02-13-2011 01:28 AM
gee
06-26-2010 07:39 PM
