Replacement Calipers
I plan on changing up my calipers as soon as I get a bigger rim with some more space :3 (the 14in Enkeis barely clear the calipers, had to do a tad of grinding). What are some good replacements that aren't too too pricey. I don't want a whole new brake kit, just some calipers for now.
I didn't really see much discussion going on about calipers in the forum. :3 Hopefully there's not already a thread about this.
any reason why? if your not looking for a big brake kit save your money.
the cheapest kit i have found is probably this one
http://fastbrakes.com/shop/index.php?cPath=28_207
FastBrakes - Upgrade your brakes - Big brake kits - Improve your braking
I guess that 11inch kit is pretty cheap, might just go with that.
well with 14's i can see why you have to grind them down. you should have just went with a spacer to avoid the grinding. if you upgrade pads and lines you should be fine with stock calipers. im running mine right now and i really dont think i need anymore stoping power unless i get really serious about tracking the car
FitFlowjoe
10-07-2010 02:42 PM
F'it_ImFromTx
02-22-2008 05:27 PM
ride_the_pony69
09-19-2007 11:59 PM
