Installing eibach sportlines
Old 02-09-2009 | 04:21 AM
SNOW's Avatar
I just installed my eibach sportline springs and had a question in mind.
Since these are progressive springs, is the more closely spaced part of the spring always supposed to be on top? Right now, according to eibach's instructions, all logos on the springs are right side up, which results in the closer spaced part being on the bottom for the fronts and on top for the rears. Is this normal?
I hope I am making sense... anyone with the same springs can chime in on this? Thanks!
Old 02-09-2009 | 04:48 AM
Rocks A GD3's Avatar
in for 1, i'm dropping my car this weekend on the pro-kit and would like some clarity on this also.
Old 02-09-2009 | 12:47 PM
Tofuman's Avatar
the rear springs have tighter coils at the top. a few aftermarket springs have printed the logo upsided down. the front springs will only fit into the perch one way, so if it doesn't line up, you know it's upside down.
check out my DIY:
https://www.fitfreak.net/forums/fit-...07-08-gd3.html
Old 02-09-2009 | 09:50 PM
SNOW's Avatar
How about the fronts? Is the closer spaced part supposed to be on top too?
Here's a pic of my fronts:
The logos are right side up, but it doesn't seem to fit properly.
Old 02-09-2009 | 10:03 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Per what Eibach says is right. The one to the left does seem a big cooked, with weight itll be fine Im sure.
Old 02-09-2009 | 11:08 PM
SNOW's Avatar
Thing is, I had to pry open the spring a little bit to slide the top hat on. This is why I am having some doubts as to whether this is the correct way to put the springs on.
Old 02-10-2009 | 04:07 AM
Tofuman's Avatar
the one on the right looks fine. the one on the left is a little off. have you tried re-adjusting it?
Old 02-10-2009 | 09:03 PM
Posts in the NUUDE
Me and a friend had to do the same installing his.
fitsmyfit
California - Bay Area Community
11-07-2019 11:28 AM
KIRK!
06-30-2013 02:03 PM
Fitting
SoCal Classifieds
05-15-2009 05:34 PM
J FIttY
05-09-2009 01:50 PM
