different springs on coilovers
Old 02-03-2009 | 01:52 AM
wait4thefit's Avatar
so im thinking about getting these kbee coilovers from another user on here but the coilovers have swift springs on them. the coilovers are fully adjustable height and dampening. so will the springs affect how low the coilovers can go? so i think the swift springs will be more stiff than the stock kbee springs am i right?
Old 02-03-2009 | 02:16 AM
solbrothers's Avatar
my skunk2 coilovers springs are WAY smaller than the skunk2 lowering springs. idk how thatd work
Old 02-03-2009 | 01:00 PM
junior40er's Avatar
because coilovers are adjustable, the coils they come equipped with are much much shorter. They are shorter but stiffer as well. Unless he cut them they will not sit as low. If he DID cut them I can imagine them being way to soft and bouncy. Normally slapping different coils other than what they came equipped with is not a good idea unless he did some research if his own and decided thats what he wanted.
Old 04-23-2009 | 11:59 AM
TheImmortal's Avatar
cutting coils will make the spring STIFFER!! soft and bouncy DO NOT go together
if they r bouncy it's because the spring is STIFFER than what the damper can handle (can't control or dampen the oscillations)
if the spring were too soft then the springs will be over damped and u will have a harsh ride
springs on coilovers seem to be of standard size, diameter wise (around 3") not length
i have bmax with different springs (megans)
it all depends on how much adjustability the damper sleeve has to compensate for different lengths, the length of the megan spring is different to the t1r that came with the coilovers but the bmax has so much adjustability (too much for most people) that it can handle roughly a 6" difference in spring length from shortest to longest
as for ride height the bmax adjustability range is way way beyond what the car can actually support
anybody switching springs for swifts to change the handling characteristics are intelligent enough to NOT CUT THEM since u can order them in any size/rates u want
Old 04-23-2009 | 12:15 PM
lowering springs ARE NOT COMPATIBLE with coilover springs but u can swap a different coilover spring for another coilover spring or u can get any size and rate from swift
Old 04-23-2009 | 12:37 PM
dela's Avatar
eibach and gc sell coilover springs in any length and spring rates you want...
08fithappy
10-07-2008 07:24 PM
ev0le
07-13-2008 09:00 AM
hiphapa
30
02-27-2008 04:03 PM
fit_love
10-10-2007 07:58 PM
