spoon sport damper & spring
Old 01-26-2009, 12:20 PM
Kurse's Avatar
I want to know if someone here is rocking this setup?
I want some feedback about the ride, the quality of the product..
I've find a good deal for it, its for a daily driver and week-end lapping like 1 time by month.
Thanks a lot!
Old 01-26-2009, 04:47 PM
eldaino's Avatar
from what i know, no one really is running this. but ben at aj's told me that the drop and ride/handling is VERY similar to the j's racing set up. (the fixed dampers that is.)
Old 01-26-2009, 05:15 PM
Kurse's Avatar
i've read it doesnt fit on the usdm fit, is it true?
Old 01-26-2009, 06:16 PM
Tofuman's Avatar
the lower bolt holes are slightly smaller on the JDM fit, so you'll have to drill these out a little larger on the Spoon front shocks.
Old 01-26-2009, 06:34 PM
Kurse's Avatar
thats it? nice!
can wait to try it
Old 01-26-2009, 07:39 PM
Kurse's Avatar
well my bad, i'll not take it finally, the guy told me it drop 50mm, but aj racing told me its only 20mm. too bad
Old 01-26-2009, 08:06 PM
spoonek4's Avatar
My brother's ex's Fit got the 1st set of SPOON damper kit with T1R ver.1 springs ever available from AJR back then.
U get really good ride quality from these Showa damper setup unless u go with progressive springs like Eibach, which might be comfortable for dd but not aggressive enough for sport suspension kit. I don't think u can lower 50mm with these setup & these dampers are NOT made to do that. U should get some coilovers if u want the slammed look.
Old 01-27-2009, 12:01 AM
Jazz GD3's Avatar
so these fixed showa damper/struts lower 50mm, from comparing to the stock shocks?
I also heard something about the spoon springs basically being the same as the tein s techs. ( i just heard this, i dont know if its true.)
Old 01-27-2009, 07:17 AM
spoonek4's Avatar
TEIN S-tech springs are lower than spoon springs. SPOON springs can't lower 50mm from stock height as far as i remember.
Old 01-27-2009, 07:06 PM
Kurse's Avatar
well i got the suspension for 700$ in new.
hope it will be nice
Old 01-27-2009, 08:18 PM
Im|Inside|Fit's Avatar
can i get that suspension for the same price =P
Old 01-27-2009, 08:32 PM
eldaino's Avatar
you should, aj racing sells it for around that price.
as far as needing coilovers to go low, it depends how low you want.
check out the tr1 damper thread. there is a nice little lowered fit in there that has the tr1 dampers and tein s-techs(they lower a little more than the tr1 springs.) perfect stance imo.
Old 01-27-2009, 08:42 PM
Kurse's Avatar
Hi Carl,
Just to let you know Spoon only lowers 20mm and the Spoon shocks and springs cost $1535CAD.
Thanks
Ben
well im curious of who make the t1r damper.
Old 02-23-2009, 02:00 AM
OCKC's Avatar
Location: San Francisco(20+yrs)/Westminister(10+yrs), CA
Did you ever put these on? got pics?
Old 03-15-2009, 01:48 PM
OCKC's Avatar
I just put this setup on my car...
Spoon suspension setup....
Before:
After:
Thanks Dan!!!
They are Great...All the comfort of stock and none of the roll or dips on turns and breaking...best money I've ever spent!!
Old 03-15-2009, 03:31 PM
spoonek4's Avatar
Before:
After:
Thanks Dan!!!
It's hard to beat Showa's valving setup. Unless u are running Ohlins.....
Old 03-16-2009, 09:06 PM
Kurse's Avatar
haha it was my kit
Old 03-16-2009, 09:08 PM
OCKC's Avatar
haha it was my kit
I thought it was when i bought it...So why didn't you put it on?
Old 03-16-2009, 09:11 PM
Kurse's Avatar
how much you have pay it?
Old 03-16-2009, 09:12 PM
Kurse's Avatar
i was broke, i've buy a crx
Quick Reply: spoon sport damper & spring
