View Poll Results: t1r or skunk2?
t1r b52
16
29.63%
skunk2 pro-c
38
70.37%
Voters: 54. You may not vote on this poll
skunk2 vs t1r
Old 01-18-2009, 11:03 PM
Spooling's Avatar
Can you adjust camber on the Skunk2 Pro-C?
Old 01-18-2009, 11:05 PM
Kurse's Avatar
I dont have the camber plate on the front, thats why i'm looking for something else..
My choice was the t1r but with the review i dont know now..
Old 01-18-2009, 11:21 PM
iheartJDM's Avatar
well if it makes you feel any better i dont regret buying the Pro C's one bit. Plus i only paid $1,170 shipped but i found a set a little cheaper maybe 10-20 dollars or so for another member who msg'd me about where i got mine from.. so when i did a search for him i ran across a cheaper set. i mean in all honesty you cant go wrong with them especially for that cheap.
Old 01-18-2009, 11:24 PM
Kurse's Avatar
1,170 ? damn! thats a good price! i've find it at 1300$ and more only
Old 01-18-2009, 11:26 PM
iheartJDM's Avatar
let me do a quick search and ill pm you some links
Old 01-18-2009, 11:52 PM
Spooling's Avatar
How is that the T1R's camber is adjustable whereas the Skunk2 isn't?
Old 01-19-2009, 12:16 AM
Kurse's Avatar
Yup! But i've find some adjust top plate in the aftermarket.
If i order the skunk2, i'll probbly take a chance and try to fit it.
I want to know if the type of the shock (Mcpherson(sorry for the error))
have the same bolt pattern to car to car.
Old 01-19-2009, 05:18 AM
revd34's Avatar
comfort=skunk2
performance=T1R
i would get T1R
Old 01-19-2009, 12:59 PM
Kurse's Avatar
D2 aluminium camber plates provide quick and easy adjustment. Designed for use with the D2 coilover. These camber plates are also compatible with other suspension systems which feature a spring with 65mm internal diameter.
Part #
Model
D2-CPxxx
All applications models
I dont know if it can fit on the skunk2 shock.
Or, ground control make universal cambr plate too.
Old 01-19-2009, 03:19 PM
eldaino's Avatar
Part #
Model
D2-CPxxx
there is a member here on the forum, unfitone, and he uses d2's. has over 40k on them and they are doing great. he also says that they CAME with camber adjustment for the front.
Old 01-19-2009, 03:39 PM
Kurse's Avatar
but i just want to use the camber plate of d2. i'll check the internal diameter of the skunk2 spring to know if it fit there.
  #32
Old 01-21-2009, 02:55 PM
FuLLy FiTTeD's Avatar
Skunk2
  #33
Old 01-21-2009, 05:38 PM
Kurse's Avatar
yummy!!!
  #34
Old 01-27-2009, 09:59 PM
08fithappy's Avatar
I just picked up some T1Rs B52 at a great price was between that and the skunks. But i went with the T1r because of the price differance. I will let u know about the ride once i get them in and installed. but the car i had before the fit a evo was one of the stiffest rides but i did not mind it i hope the T1R are good coils
  #35
Old 01-27-2009, 10:27 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
It is. Loosen the top and lower strut bolts, kick the top in and tighten the hell out of them.
Per the pic posted below me, notice the top hole on the front assembly is oblonged? Its for adjustment.
Pretty sure you cant run camber plates on the Fit. The way the strut is designed its not possible.
You need camber bolts or widened strut holes.
  #36
Old 01-28-2009, 08:28 AM
SHG_Mike's Avatar
Ray is correct, unless you find a way to use the Top mount that some JDM models have
  #37
Old 02-21-2009, 12:34 AM
radareclipse's Avatar
You can order from Skunk, softer spring rates which I strongly recommend for the street. They come with 8k/6k. Skunk has 6k for the front, but nothing softer for the rear. I think ideally the combo of 5.5k frt and 4.5k rear would be the ticket but I can only wish.
  #38
Old 02-21-2009, 12:51 AM
FitVic's Avatar
i've had my pro-cs for about...... 1-2 weeks so far and I'm still working out the kinks to how it rides and stuff. Unfortunately it took me this long because i work and barely have time to fix/tune it properly in one day and now that my cars in the shop getting repaired wow that put it on a longer halt.
  #39
Old 02-21-2009, 01:17 AM
solbrothers's Avatar
pro c's ftw!!!!!!!!!!!!!!!
  #40
ive had my pro c's for about 8k miels. i liek, em
ciref8
10-17-2014 12:31 AM
Special
California - Bay Area Community
09-02-2011 01:26 AM
JCrimson
01-30-2011 03:20 PM
ericman20
26
10-21-2009 02:59 PM
shazaam
07-10-2009 07:29 PM
Quick Reply: skunk2 vs t1r
