Question: Tanabe GF210 Springs w/ Stock Shocks
Old 12-30-2008 | 07:37 PM
RandomKoko's Avatar
1.5F & 0.9R
How long will my stocks shocks will last. i'm asking because i'm planning on buying this next week. how long will my stock shocks last? 10k? 20k? 30k? 40k???
thanks.
Old 12-30-2008 | 08:32 PM
FitVic's Avatar
EDIT: I just realized your question to lol I have exactly around 15,000 miles on the shocks and GF210 springs
I have this set up and have been running it for 5-6 months. I honestly have been doing backroad crazy touge driving with friends in the summer EVERY WEEKEND lol. My shocks are still fine too. I would say just invest in coilovers now because eventually you will be getting them like most people so why not do it right the first time.
Old 12-30-2008 | 09:35 PM
RandomKoko's Avatar
some touge run like initial d i bet. lol that's my target though, since i donot want to waste a lot of money right now... i'm just going to get gf210 today... hmmm.. hopefully my axle won't pop out.
Old 12-30-2008 | 09:38 PM
kylerwho's Avatar
spoon fed
do it smart and your axle wont pop out.
springs with oem struts is the cheap way to do it. save up and get the t1r struts to go along with your springs.
Old 12-30-2008 | 10:12 PM
Shaggs2Dope's Avatar
Frequent FitFreak Poster
usually with sport springs you can get 50-60k outta stock shocks on most cars. But much after that they will start leaking and squeakin. You can pick up a set of tokico blues for cheap when they do go out, or switch to air shocks in the rear for better ride and adjustable load handling
Old 12-30-2008 | 10:41 PM
RandomKoko's Avatar
ohh.. mmm.. i was wondering why do shocks do blow out. i mean... where does it mostly handle the stress.. spring rate? or ride height? or both?
Old 01-01-2009 | 07:07 AM
RandomKoko's Avatar
do you scrape your front lip? ekk that one of the things i was also worried about.
Old 01-01-2009 | 07:12 AM
solbrothers's Avatar
if you are lowered, that is a risk you take. there probably isnt any paint on the underside of my front lip, but you cant see that when standing there, or even if you are parallel w/ the front lip. only when you look under the car, or it is jacked up
Old 01-01-2009 | 03:37 PM
FitVic's Avatar
yeah right after i put the springs on a friend and I went for a test drive. During that drive (which was 20 minutes) i scraped it like times LMAO i wasn't used to the height. Now i really don't hit the lip since I'm so used to it. One thing that i usually hit is my resonator on my Megan B-Pipe. That thing hangs low! Imma fix that problem though.
Old 01-02-2009 | 12:13 AM
RandomKoko's Avatar
i wish when i received mines next week hopefully my shocks will last for 50,000k. =]
Old 01-08-2009 | 10:57 PM
saveacivic's Avatar
The 2009 fits have a decently stiff spring rate to them compared with the previous years. And no matter what anyone tells you, the shocks would have been made to handle at least the rate of the stock springs. So what you need to do is figure out the stock spring rate, and the rate of the springs you are going to buy. Then there is no opinion, only fact. I have been trying to do the same thing but I cant friggin find the spring rates of the stock springs of the 2009. Anyone know?
Progress says there springs will be available for sale in February. I'm going to wait for them either way. Maybe they can tell us the stock spring rates?
Old 01-09-2009 | 03:32 PM
RandomKoko's Avatar
ok.. i've got the springs. i've also read that using a jack to hold up the ball joint/wheel hub to prevent the axle from popping out.. since i don't really want to tie it from the chassis. have anyone just jacked up the balljoint/wheel hub? and successfully remove the front strut? =] almost done.
Old 01-09-2009 | 05:13 PM
Sugarphreak's Avatar
Push My Button
Get a life you f-cking signature spammer.
and REPORT
Old 01-09-2009 | 05:14 PM
Push My Button
I have had my GF210's in for about 20,000kms so far. The shocks seem to be holding up nicely despite the pothole ridden city I live in.
Old 01-09-2009 | 09:27 PM
RandomKoko's Avatar
did you hold the axle in place with a jack or scissor jack in place so it would not drop?
Old 01-09-2009 | 11:12 PM
FitVic's Avatar
hehe i did mines wrong and didnt hold it up high enough so it fell out. i got lucky that it only took 45mins to pop back in. Just wiggling it
Old 01-24-2009 | 05:21 PM
RandomKoko's Avatar
yes! i finally installed mines for 5 hours. damn! i felt so lonely by myself. could've called my friends up but i knew they were working. the axle pop out but it wasn't too hard to push it back in only took 3-5 mins. =D
anyways. i was wondering about the rear springs.. the more coiled facing bottom or the more coiled facing top? cause i installed mines more coiled on facing the bottom?
Old 01-24-2009 | 06:17 PM
HONDAMATIC's Avatar
i got stock struts too, took under an hour to install on my own
Old 01-24-2009 | 06:28 PM
RandomKoko's Avatar
lucky. i was rushing that's why and it was at night too only had flash light with me. i was wondering about the rear springs.. the more coiled facing bottom or the more coiled facing top? cause i installed mines more coiled on facing the bottom? ______________
Old 01-25-2009 | 02:23 AM
HONDAMATIC's Avatar
i just made the letters on the spring right side up.. or the close coils on the bottom.. i did it at night too.. had to hurry before the old lady next door calls the cops on me
