EG civic calipers on Fit/Jazz?
Old 02-13-2006, 11:45 AM
Sleeper's Avatar
Hi guys, will the OEM calipers of an EG civic bolt on to the honda fit/jazz?
Old 02-14-2006, 12:47 AM
tysonzane's Avatar
Im also curious as to if SIR (EG, EK, EF etc) calipars, rotors, pads and lines will bolt up to the front no problems and what is involved in the rear to convert to disc...
Old 02-14-2006, 11:00 AM
b26cw's Avatar
Yup! I've done it with EK parts for rear, converted from drum brake type to disc brake.
Front 295mm AP Racing Brake Kit for Honda Fit with APP Brake Line.
Rear modified from EK4+pad, AEM slotted rotor 286mm diameter.
http://autoshow.permaisuri.com/Conte...20050927212954
Old 02-14-2006, 08:00 PM
leekiong's Avatar
if fit convert the drum brake to disc brake of ek, it need any modification?? will it effect the function of abs?
Old 02-14-2006, 11:31 PM
tysonzane's Avatar
Yeah so what EK parts will i need to convert the rear to just a standard EK disc setup?
Disc
Calipar
Pads
Lines
What else? Is there a mounting point for the calipar?
Old 02-15-2006, 03:22 AM
vividjazz's Avatar
Someone that Posts too much
ABS only applies on the front wheels with the way the Jazz is set up so changes to the rear won't have any impact on it.
Old 02-15-2006, 06:34 AM
b26cw's Avatar
Disc
Calipar
Pads
Lines
Knuckle shaft for mounting the Caliper.
Old 02-15-2006, 06:27 PM
Sleeper's Avatar
you mean we would need to replace even the knuckle to fit the EK calipers?
Old 02-15-2006, 11:45 PM
Dan GSR's Avatar
i really don't understand which parts you replaced
since the EK is double wishbone
and the GD is torsion bar
so you can't just use the EK trailing arm
Old 02-15-2006, 11:47 PM
Dan GSR's Avatar
for the front it won't work
i do belive the fronts are the same as the DC chassis
the EG brakes are smaller
Old 02-15-2006, 11:51 PM
tysonzane's Avatar
Smile
Thanks. Was it an easy conversion? I have also heard there are some problems with the length of the hand brake cable. How did you get around this and did you use a EK item or the original Jazz Fit one?
I bet the larger brakes and especially the Discs on the rear make quite a nice difference
Old 02-15-2006, 11:56 PM
Dan GSR's Avatar
yeah i'd love to learn how to do the rear disc with parts avail to the US market
i'll probably be doing 11" brakes in the front...and would like to maintain a good brake bias
track pads in the front with a stock rear drum...is gonna make the rear end feel really light and twitchy
Old 02-16-2006, 04:18 AM
leekiong's Avatar
i got a problem with my car when i drive very slowly, got a bit noise at front tyre there.something like metal to metal one" KI....KI....KI.....KI ", something like that, when drive at normal speed then no noise already.anyone who got face this problem b4??
Old 02-16-2006, 05:03 AM
b26cw's Avatar
Yup! The handbrake cable also must be replaced with EK part.
Old 02-17-2006, 05:53 PM
IN2TURBOS's Avatar
Did you also replace the proprotioning valve with one from the EK? I know that when rear disk conversions are done on other hondas it needs to be replaced because drum/disk run at different pressures.
Old 02-18-2006, 05:04 PM
dougiepants's Avatar
Avid FitFreak Poster
I will be interested to see the cost of this and how easy/hard it will be
Old 02-20-2006, 11:34 PM
blacksirek's Avatar
Actually drum brakes require more pressure than disc brakes so you might be able to get away with the standard proportioning valve.
Old 02-23-2006, 11:56 AM
Gioujazzgr's Avatar
Hi I am new here and i need help.. I look for Bodykit.. If anybody read my message please send me
Old 02-23-2006, 10:02 PM
myfit.org's Avatar
i know for sure front EG brake parts can be used. If i recall the hub assembly and brake rotors are the same. We had to quick source some when the Spoon fit needed some parts day before a 25hour race. ill see if i can find out EXACTLY which cross over.
Old 02-24-2006, 12:18 AM
Sleeper's Avatar
hi thanks for the reply! acutally i want to confirm if the EG caliper does bolt on? not just the rotors
Quick Reply: EG civic calipers on Fit/Jazz?
