D2 Coilovers
Old 02-18-2009, 06:18 PM
rvall004's Avatar
I was having a little trouble too with the sway bar making some noises when doind a full turn...it was rubbing with the axle..so what I did was took out both front coils, and then the sway bar can go up and down..i put it down and the tie rod that comes with the coilovers is what pushes the sway bar down when u putt it at the right hieght
  #62
Old 02-18-2009, 08:41 PM
Illmatic07's Avatar
So i'm sorry but I am a little confused with what you are saying. So the sway bar needs to be lower to clear the axles? So to do that I need to put the tie rods that are on the coilover lower on the threads? Any more clarification would be great. Sorry for being a noob.
  #63
Old 02-18-2009, 08:47 PM
rvall004's Avatar
u dont have to put it in a lower thread jsut make the end links long enough so it pushes the sway bar down away from the axle.
  #64
Old 02-18-2009, 11:34 PM
Illmatic07's Avatar
Ohhhhhh. that makes more sense now. I will get under the car on Friday and make sure it still makes sense when I see everything. haha. Thanks again.
  #65
Old 02-18-2009, 11:47 PM
rvall004's Avatar
sure no problem..
  #66
Old 02-19-2009, 05:19 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
The sway is suppose to be centered in between the axles and the lower controls arms.
The best way to adjust this is the car on the ground.
  #67
Old 02-20-2009, 11:00 AM
Illmatic07's Avatar
How in the world would I do that with the car on the ground? I have to drive on boards just to get a jack underneath it.
  #68
Old 02-20-2009, 11:46 AM
808duece's Avatar
had the same problem but got it fixed w/ a lot of trial and error...
  #69
Old 04-02-2009, 12:05 AM
DrKelso's Avatar
Ramps? *shrug*
  #70
Old 04-02-2009, 12:07 AM
Illmatic07's Avatar
^^^Wow back from the dead! haha
  #71
Old 04-05-2009, 07:18 PM
DrKelso's Avatar
Who? Me? hahaha
  #72
Old 04-27-2009, 02:43 AM
showcaseGD3's Avatar
funny.... i had no issues with my d2?
just speed bumps after they went on. LOL
  #73
Old 05-26-2009, 03:17 PM
Bragi's Avatar
I just put my D2's on over the weekend and am waiting till tomorrow to get an alignment. Am i going to need a camber kit? Also did you guys have any trouble with the toe? Just want more info for when i talk to the shop doing the alignment. Anything you guys think i should tell em?
Dan
  #74
Old 05-26-2009, 04:28 PM
Illmatic07's Avatar
I didn't need a camber kit. I think it just depends if you want crazy negative camber. They were able to get -1.8 in the fronts but a more tuner friendly shop may be able to get more. As far as toe I just had them set it to zero and they did.
  #75
Old 05-26-2009, 10:10 PM
Bragi's Avatar
Thanks for the info illmatic. helped out a ton.
  #76
Old 06-02-2009, 01:39 PM
Bragi's Avatar
I am in need of lowering my front a little bit.. But i cannot figure out how without taking the 2 bolts out and removing it all. Is that the only way?
Also the guys who did my alignment could only camber the front to -1.5 which i figure will be fine.
  #77
Old 06-04-2010, 03:22 PM
Fit_Mike's Avatar
Ok i know this is old thread, but its no point of making a new one...I just put on my D2's and its really bouncy...Do i not have the shocks adjusted right I dont know? Maybe they are like that...I had Tein super streets on my del sol and it was the best ride no movement...But let me know, need some help on this!!!
  #78
Old 06-11-2010, 01:31 AM
fork_nSpoon's Avatar
that suxs. i really wish koni or tokico bring out their line of adj. dampers for the fit.
toad37
3rd Generation GK Specific Suspension & Brakes Sub-Forum
32
10-08-2014 07:29 PM
Smurf_GE
70
05-07-2012 10:58 PM
emmad00d
26
08-30-2008 10:29 PM
SukebePAUr
07-18-2008 09:47 AM
Mark94
04-19-2007 12:34 AM
Quick Reply: D2 Coilovers
