Bouncy Ride....Help Fix
Hello All
My Fit has a set of Skunk2 springs installed with the stock struts.
Over the last month I've been noticing more bounce in the car, which I really don't like.
What would be the fix for this?
New Struts, is what I was thinking but maybe Skunk2's are just bouncy?
Any aftermarket springs are going to be bouncy because they're stiffer than the OEM springs. You're gonna feel everything in the road.
Aftermarket shocks would fix this, but you have to make sure you get a set that complements the springs, otherwise the ride quality will barely change.
Ok, enough thread jacking. Back to the OP's original topic!!!!
Hello All
The fix is different (taller,softer) springs but then of course thats out of the question cause you wouldn't be lowered.
Everyone should understand that when you reduce the travel of a vehicle's springs (dropping or lowering) the springs will have to be shorter and stiffer. And not necessarily faster atround corners.
i agree. especially on street you want suspension travel and keeping
things smooth, not stiff. stiff usually results in wasted energy.
The only really successful drops we see are 1" or so dropped. Any more and the ride is bouncy.
If your drop is more than an inch and a quarter, yo may be OK with softer springs and less drop but otherwise, sorry.
Over the years we have undropped probably a half-dozen cars but most of them had 2" or more drops
OK, the thread is not stickied, but it SHOULD BE!!!!! (Ray)
here you go. Read through it. there is a lot of good info in here.
https://www.fitfreak.net/forums/fit-...tml#post221399
Last edited by cavie187; 07-13-2008 at 10:23 PM. Reason: finally linked. OMGWTFBBQ
The stiffer the spring (lb per inch) the stiffer the shocks have to be to control the spring. and therefore the more bouncy the ride.
Both are components of spring stiffness.
As spring compression rate increases so does the rebound rate. Its metal.
Valving the shock is merely a means of independently slowing the rates in either case; but if you slow the movement too much the spring has no function. Its only salvation is the length of travel that can be controlled.
That means the shorter the spring the stiffer the spring and shock is to cover a reduced travel; and the stiffer the shock control the more bouncy the suspension.
The trick is how much bounce can you tolerate.
